SeonTheNeon's avatar
SeonTheNeon
Follower
Dec 29, 2016
C7000-100NAS - 100 Mbs Download, 1 Mbs upload?
I am currently using Cox Communications as my service provider. The modem/router duo (C7000-100NAS) I have is running firmware version V1.01.18. I have heard numerous reports about this model having very poor performance. Whilst I am receiving 100 Mbs download speeds, my upload, of which I am very reliant upon, is reaching a maximum of 1 Mbs. This is very startling for me, as I am paying for 100 down and up. Any suggestions or reasons for this happening? The event logs and cable connection are posted below.
Event Log:
TimePriorityDescription
1970-1-1, 00:00:40Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:43Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:38Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2016-12-26, 12:43:43Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:1b:54:ca:f9:8b;CM-QOS=1.1;CM-VER=3.0;
2016-12-28, 09:57:26Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:1b:54:ca:f9:8b;CM-QOS=1.1;CM-VER=3.0;
1970-1-1, 00:00:37Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:39Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2016-12-28, 17:25:16Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:1b:54:ca:f9:8b;CM-QOS=1.1;CM-VER=3.0;
1970-1-1, 00:00:37Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2016-12-29, 22:05:14Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:1b:54:ca:f9:8b;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 22:07:09Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:1b:54:ca:f9:8b;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 22:07:44Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:1b:54:ca:f9:8b;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 22:07:57Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:1b:54:ca:f9:8b;CM-QOS=1.1;CM-VER=3.0;
1970-1-1, 00:00:42Notice (6)WiFi Interface [wl0] set to Channel 1 (Side-Band Channel:N/A) - Reason:INIT
1970-1-1, 00:00:42Notice (6)WiFi Interface [wl1] set to Channel 153 (Side-Band Channel:N/A) - Reason:INIT
1970-1-1, 00:00:49Notice (6)Honoring MDD; IP provisioning mode = IPv4
1970-1-1, 00:00:51Warning (5)DHCP WARNING - Non-critical field invalid in response ;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:1b:54:ca:f9:8b;CM-QOS=1.0;CM-VER=3.0;
2016-12-29, 22:09:20Notice (6)TLV-11 - unrecognized OID;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:1b:54:ca:f9:8b;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 22:09:24Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:1b:54:ca:f9:8b;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 22:10:02Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:1b:54:ca:f9:8b;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 22:36:55Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:1b:54:ca:f9:8b;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 22:51:19Notice (6)WiFi Interface [wl0] set to Channel 1 (Side-Band Channel:5) - Reason:INTERFERENCE
2016-12-29, 22:56:07Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:dc:30:e8;CMTS-MAC=00:1b:54:ca:f9:8b;CM-QOS=1.1;CM-VER=3.0;
Cable Connection:
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel855000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnabledBPI+
IP Provisioning ModeHonor MDDhonorMdd(4)
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1LockedQAM25622855000000 Hz9.8 dBmV39.3 dB00
2LockedQAM2561729000000 Hz10.5 dBmV40.2 dB00
3LockedQAM2562735000000 Hz9.9 dBmV40 dB00
4LockedQAM2563741000000 Hz9.9 dBmV40 dB00
5LockedQAM2564747000000 Hz9.8 dBmV39.9 dB00
6LockedQAM2565753000000 Hz10.4 dBmV40 dB00
7LockedQAM2566759000000 Hz10.7 dBmV40.1 dB00
8LockedQAM2567765000000 Hz10.7 dBmV40 dB00
9LockedQAM2568771000000 Hz11 dBmV40 dB00
10LockedQAM2569777000000 Hz11 dBmV40 dB00
11LockedQAM25610783000000 Hz10.9 dBmV40 dB00
12LockedQAM25611789000000 Hz10.9 dBmV39.9 dB00
13LockedQAM25612795000000 Hz10.9 dBmV39.9 dB00
14LockedQAM25613801000000 Hz10.9 dBmV39.9 dB00
15LockedQAM25614807000000 Hz10.6 dBmV39.8 dB00
16LockedQAM25615813000000 Hz10.4 dBmV39.7 dB00
17LockedQAM25616819000000 Hz10 dBmV40.8 dB00
18LockedQAM25617825000000 Hz10 dBmV40.8 dB00
19LockedQAM25618831000000 Hz10.1 dBmV40.9 dB00
20LockedQAM25619837000000 Hz9.9 dBmV40.6 dB00
21LockedQAM25620843000000 Hz9.8 dBmV40.5 dB00
22LockedQAM25621849000000 Hz9.9 dBmV40.8 dB00
23LockedQAM25623861000000 Hz9.1 dBmV40.3 dB00
24LockedQAM25624867000000 Hz9 dBmV39.9 dB00
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA15120 Ksym/sec38600000 Hz38.1 dBmV
2LockedATDMA25120 Ksym/sec32200000 Hz38.3 dBmV
3LockedATDMA35120 Ksym/sec25800000 Hz38.3 dBmV
4LockedTDMA and ATDMA42560 Ksym/sec21000000 Hz38.3 dBmV
5Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
6Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
7Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
8Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
Current System Time:Thu Dec 29 23:02:57 2016
1 Reply
  • I have the C7000-100NAS as well and had simular results.
    I fixed them but replacing exsiting cable with new RG6 cable and connectors rated to 1000MHz. and what helped the most improving upload speeds was using a 5-1005MHz spiltter with EMI shielding and wiring it to a proper earth ground if your cable drop isn't grounded when it comes into the house.
    Try this
    https://www.amazon.com/gp/product/B007YV0UQW/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
    try hooking it up grounded and ungrounded and compare results.
    It will also drop your power level down a bit which might not be a bad thing in your case.
    Replace all splitters yearly or when performance slows!
    If all else fails have the cable company to install a new drop and have a line tech come out and adjust your neighboorhood cable power amps.
