ezicefield
Jan 27, 2016Follower
C7000-100NAS randomly drops internet connection
Hello, My C7000-100NAS modem seems to randomly drop it's Comcast connection. This happen on 2.4 ghz, 5 ghz, and wired connections. There is no pattern, however the dropped connection usually last...
SupaPig
Mar 27, 2016Guide
I have similar problems with my C7000 and it's now getting to the point where I may have to dump this device. All I want is reliable internet. I've got Time Warner and I don't think the problem is with them. I'm a Network Engineer by trade and by no means does that make me "a "Netgear" expert, it does however mean I possess the ability to troubleshoot further and provide additional information. I've had my fair share of crappy wireless devices along with excellent Enterprise class in Cisco, AeroHive, Juniper, Aruba etc. I'm about to say "to heck with it" and spend $500-1k on an Enterprise device as I've wasted close to that on Linksys and Netgear devices over the years.
The C7000 will randomly drop my internet connection for 60 seconds to 5 minutes. Sometimes, it requires a complete reboot. Sometimes it wakes up from being half dead and I need to do nothing. However, the issues are sporatic but obvious and I would guess Netgear would be fully aware of this bug. One second it will drop ICMP traffic to the internet but the C7000's interface tells me my "Cable Connection" is good and I can ping my LAN interface. Then, it will stop responding to ICMP on it's LAN (internal RFC1918 address) interface but Internet traffic still passes fine. For example, as I'm typing this, I can't ping my LAN interface but I can ping 8.8.8.8 without issue. I just looked again and now my LAN interface responds to ICMP but internet is dead. A few minutes later without doing anything, both start responding. Either way, it's virtually impossible to blame Time Warner for this issue when the local LAN interface won't even respond to ICMP (randomly) and internet traffic responds fine. It's also obviously not a weak wireless signal when I can pass sub 20ms packets to most destinations on the internet but not ping my LAN interface. Bottom line, the C7000 displays such erradic behaviour it doesn't seem stable or this firmware release needs work. Time Warners crappy rented "Technicolor", while having weak wireless signal, is at LEAST reliable.
Netgear needs to get on with a stable firmware release or lose customers. Most people don't know how to properly troubleshoot an issue and for costing $200 plus, they shouldn't need to constantly "troubleshoot" what's becoming pretty evident as a firmware issue. Word of mouth spreads and it reflects in reviews.
- Drew2Apr 07, 2016Star
Word does spread. The Co I work for has stopped recomending Netgear for home offices. That only impacts a dozen or so sales at best, but it's a pea shooter across the bow - lol
- SupaPigApr 28, 2016Guide
Yeah, mine get worse as time goes on. It isn't wireless coverage or signal overlap as I'm a Network Engineer by trade and know how to scan and scope interference issues.
As a good test or temp fix, if you want to see if you're having the same problems as I am (which is likely), when you have wireless related issues: FIRST, disconnect from your 5Ghz network either by disabling/re-enabling wireless or connect to your 2.4Ghz network THEN switch back to 5. Either way, when you disconnect and reconnect from your 5Ghz network, it will (or mine does) connect and work fine for a period of time (10-15 min). Some longer than others. On occassion, I just have to power cycle the C7000 altogether.
I went ahead and took an AeroHive AP which is enterprise class and placed it on a different frequency as the Netgear using the netgear as a local router and the AeroHive as an isolated extension but different network and BAM, the AeroHive works flawlessly as a wireless router while the Netgear (which is in the same room) continues to flake out wirelessly and sometimes as a modem.
It just can't seem to handle any kind of small error correction. Instead, it flakes out for all clients on the 5Ghz network without correcting whatever issue it's having until it reinitiates that connection either by disconnecting the client or restarting the C7000. Pretty bad bug IMO.
- rmacbethApr 28, 2016Apprentice
SupaPig It is still happening with this account--- I have wired most of the main computers on Ethernet GB backbone so there are only a few that will use the 5Ghz along with customers will use the 2.4Ghz. Looking at the logs it is doing just like you were talking about. I have been working with Netgear support for approx. 2+ years on my home base system (started out with R700 than R7500 and now R7800) due to many issues with code and hardware. The current one that I am now using R7800 has been more stable but it has it issues that we are still working with. If this account were tasking the 5Ghz they would be complaining more. Since for the most part they are not noticing the errors due to them not using their laptops, etc. on a ongoing basics. They are using them between patients they are working on for updating info about what they are doing with each patient. This does not let Netgear off the hook to fix the code.
