| Time | Priority | Description |
| 2016-5-29, 21:32:32 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:01:5c:64:5a:53;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 21:32:41 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 21:32:42 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 21:32:46 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 21:32:46 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 21:32:49 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 21:32:50 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 21:32:50 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 21:32:51 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 21:32:52 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 21:32:52 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 21:32:54 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 21:32:54 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 21:37:18 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 21:37:31 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 21:37:32 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 21:37:46 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:01:5c:64:5a:53;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:38 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:45 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:01:5c:64:5a:53;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 21:40:36 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:01:5c:64:5a:53;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:37 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:43 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:01:5c:64:5a:53;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 21:47:47 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:01:5c:64:5a:53;CM-QOS=1.1;CM-VER=3.0; |
| 1970-1-1, 00:00:41 | Notice (6) | WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INIT |
| 1970-1-1, 00:00:41 | Notice (6) | WiFi Interface [wl1] set to Channel 153 (Side-Band Channel:N/A) - Reason:INIT |
| 1970-1-1, 00:00:46 | Notice (6) | Overriding MDD IP initialization parameters; IP provisioning mode = IPv6 |
| 1970-1-1, 00:00:56 | Warning (5) | ToD request sent - No Response received;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:01:5c:64:5a:53;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:57 | Error (4) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:01:5c:64:5a:53;CM-QOS=1.1;CM-VER=3.0; |
| 1970-1-1, 00:00:57 | Error (4) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:01:5c:64:5a:53;CM-QOS=1.1;CM-VER=3.0; |
| 2016-5-29, 22:32:46 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:01:5c:64:5a:53;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 22:32:53 | Notice (6) | Overriding MDD IP initialization parameters; IP provisioning mode = IPv6 |
| 2016-5-29, 22:33:07 | Error (4) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:01:5c:64:5a:53;CM-QOS=1.1;CM-VER=3.0; |
| 2016-5-29, 22:33:07 | Error (4) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:01:5c:64:5a:53;CM-QOS=1.1;CM-VER=3.0; |
| 2016-5-29, 22:33:13 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:01:5c:64:5a:53;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 22:33:18 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:01:5c:64:5a:53;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-29, 22:33:22 | Notice (6) | Overriding MDD IP initialization parameters; IP provisioning mode = IPv6 |
| 2016-5-29, 22:33:32 | Error (4) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:01:5c:64:5a:53;CM-QOS=1.1;CM-VER=3.0; |
| 2016-5-29, 22:33:32 | Error (4) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:01:5c:64:5a:53;CM-QOS=1.1;CM-VER=3.0; |
| 2016-5-29, 22:35:05 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=40:5d:82:f4:30:08;CMTS-MAC=00:01:5c:64:5a:53;CM-QOS=1.1;CM-VER=3.0; |
