ezicefield
Jan 27, 2016Follower
C7000-100NAS randomly drops internet connection
Hello, My C7000-100NAS modem seems to randomly drop it's Comcast connection. This happen on 2.4 ghz, 5 ghz, and wired connections. There is no pattern, however the dropped connection usually last...
8th_Day
Jun 29, 2016Aspirant
Need help. The firmware release has not solved the issue with Comcast. We have Comcast Internet only since they started in Illinois area and never had cable TV. Invested in the newer technology because you had a Comcast Certification, so I did not expect these types of issues.
With instructions, we can do and check anything.
Hardware Version | 1.05 |
| Mac & Windows Network | |
| Firmware Version | V1.01.20 |
Internet only - No Cable - Comcast
Wireless is Itv and Roku
Loosing connections.
These events keep happening over and over again.
Fouter Event Log
| 1970-1-1, 00:00:39 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=b0:7f:b9:d7:20:80;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:42 | Notice (6) | WiFi Interface [wl0] set to Channel 6 (Side-Band Channel:N/A) - Reason:INIT |
| 1970-1-1, 00:00:42 | Notice (6) | WiFi Interface [wl1] set to Channel 153 (Side-Band Channel:N/A) - Reason:INIT |
| 1970-1-1, 00:00:46 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=b0:7f:b9:d7:20:80;CMTS-MAC=00:01:5c:7f:9a:5a;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:51 | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
| 2016-6-27, 16:15:21 | Warning (5) | Dynamic Range Window violation |
| 2016-6-29, 09:47:55 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:d7:20:80;CMTS-MAC=00:01:5c:7f:9a:5a;CM-QOS=1.1;CM-VER=3.0; |
| 2016-6-29, 09:47:55 | Warning (5) | Dynamic Range Window violation |
| 2016-6-29, 13:43:12 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:7f:b9:d7:20:80;CMTS-MAC=00:01:5c:7f:9a:5a;CM-QOS=1.1;CM-VER=3.0; |
| Frequency start Value | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Startup Procedure | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Current System Time:Wed Jun 29 15:05:57 2016 |
8th_Day
Additional error just moments ago
| 2016-6-29, 15:05:51 | Notice (6) | WiFi Interface [wl0] set to Channel 1 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
This happened between two other errors dated 2016-06-27
Remember that only iTV and Roku are wireless
Thank you
