ezicefield
Jan 27, 2016Follower
C7000-100NAS randomly drops internet connection
Hello, My C7000-100NAS modem seems to randomly drop it's Comcast connection. This happen on 2.4 ghz, 5 ghz, and wired connections. There is no pattern, however the dropped connection usually last...
NCsandhills
Sep 08, 2016Guide
I ran the test on "https://www.dslreports.com/speedtest/". Great testing site, with lots of information. I experienced the same change in download rates as reported before - initial test was low, second test was per contract with TWC, nearly a 5-fold change in the download rate of the initial try. So, I still conclude that "If the repeated tests start with low rates and continue to increase, then it is most likely the ISP." If this is casued by the router/modem - I have yet to determine how/why.
Drew2
Sep 08, 2016Star
Look at channels available / channels synced (bonded) When you get advertized rate (for example 300mb down) it will be 24/16. At less that advertized rate, say 100mb down it's 24/6 on the dslreport speed test - even though the modem still says 24/16 channels are bonded/synced.
