ezicefield
Jan 27, 2016Follower
C7000-100NAS randomly drops internet connection
Hello, My C7000-100NAS modem seems to randomly drop it's Comcast connection. This happen on 2.4 ghz, 5 ghz, and wired connections. There is no pattern, however the dropped connection usually last...
Rreckr
Nov 01, 2016Aspirant
DarrenM
There doesn't seem to be a time of day that the problem is worse. It will randomly drop out when accessing the NAS from the Blu-ray or using the wired desktop PC. Ive been calling Gear head tech support every morning for the last few days. This morning they decided that the problem is the modem. They required a copy of my sales receipt because there was a problem with the serial number. So I emailed what they needed in order to work on a replacing the modem. Hope to hear back from them within a day or two. But when I have issue again in the morning I plan on calling again to check.
- DarrenMNov 01, 2016Sr. NETGEAR Moderator
Hello Rreckr
When you are having these issues can you copy the modems logs and post them here you can get the logs in the modems settings then click Advanced-Administration-Logs.
DarrenM
- polishkazNov 06, 2016Guide
DarrenM, I am having very similar issues. My ISP is Cox cable, currently my router is running Version V1.01.18. The Netgear website states for this service provider I should only be running Version V1.01.15. Whats up with that, who is right? Is there anyway for me to download and install this older version? Cox claims they can't push it and I can't find it in the download section of the Genie or website.
- DarrenMNov 09, 2016Sr. NETGEAR Moderator
Hello Polishkaz
It could just be old info on the web page but there is no way to change the firmware on cable modems whatever the ISP is pushing to the modem is what firmware it will use.
DarrenM
