ezicefield
Jan 27, 2016Follower
C7000-100NAS randomly drops internet connection
Hello, My C7000-100NAS modem seems to randomly drop it's Comcast connection. This happen on 2.4 ghz, 5 ghz, and wired connections. There is no pattern, however the dropped connection usually last...
DarrenM
Nov 09, 2016Sr. NETGEAR Moderator
Hello Polishkaz
It could just be old info on the web page but there is no way to change the firmware on cable modems whatever the ISP is pushing to the modem is what firmware it will use.
DarrenM
polishkaz
Jan 08, 2017Guide
DarrenM, I ended up having to buy another companies Modem and router and everything works perfectly. Haven't had a drop out in weeks. I am not sure what is up with this product but it is certainly not worth the money I paid for it and we should be refunded. The thing worked in Bridge mode without dropouts but thats not what I bought it for. Lesson learned, no more Netgear products.
- reustinJan 26, 2017Initiate
We have this router as well - wanted to add my complaint to the list and also ask some questions. I'm a little surprised no one has included this info: what kinds of machines/operating systems do you guys have?
We have two MacBook Airs running El Capitan (10.11.6). These are our main computers and they both drop the internet connection every 3-15 minutes. It's MADDENING. We have the 2.4 and the 5 GHz networks set up, so when it freezes, we just switch to the other one and it gets us another 3-15 minutes.
But on our other devices the connection is fine and never drops out:
Toshiba PC running Win 7
2 iPhones running iOS 9.3
Apple TV
...so it seems to just be the mac computers.
Do you guys that are having problems also experience them on Macs or only on Macs or on other types of devices?
Thanks.
- NCsandhillsJan 26, 2017Guide
The "wi-fi" connection depends on two pieces of hardware. The PC's adapter and the Modem/Router.
Since some of the connected units remain "connected" while the MacBooks tend to disconnect - you may need to check the adapter's hardware and settings.
Maybe the adapter's "energy or sleep setting" is allowing the adpater to turn-off when transmission is inactive?? Otherwise, check if the adapter's drivers are up to date, and if the settings are correct. The situation you are experiencing suggests that the problem is most likely the Mac PC's, and their adapter hardware and/or settings -- or possibly some other MacBook setting that causes the disconnect.
Thanks for your reply!
Absolutely agreed–it must be something about the MacBooks' ethernet adapters or their firmware/drivers/software specifically. However, neither of us experience this issue with any other WiFi access points, so it's also something about the combination of our computers AND this particular make & model of router (and we had no issues until we got this router recently). Neither Apple or Netgear is off the hook!
I was hoping to see if other people here were experiencing this correlation of it happening specifically with Macs as well.
PS: As to sleeping/inactivity; this happens while we are in the middle of streaming or browsing etc.
P.P.S. I'm also an NC native (triangle area) :)
- 8th_DayJan 27, 2017Aspirant
We us both Mac and Windows on our network. They are wired and not wireless. We have issues with both.Windows 10 Pro - Toshiba
Macintosh ElCapitan 10.11.6 - Imac 27in
This is getting so bad, that we almost couldn't use the internet yestserday at all. Here is the log taken this morning at 9:30.
[DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Fri Jan 27 09:00:48 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Fri Jan 27 09:08:34 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.76.76, port 53 Fri Jan 27 09:12:52 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 09:35:18 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 09:41:30 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 09:47:58 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.76.76, port 53 Thu Jan 26 10:01:31 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 10:10:58 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 10:15:15 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.76.76, port 53 Thu Jan 26 10:22:44 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.76.76, port 53 Thu Jan 26 10:38:43 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 10:52:31 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 11:10:30 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.76.76, port 53 Thu Jan 26 11:37:25 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.76.76, port 53 Thu Jan 26 11:45:00 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 11:50:11 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.76.76, port 53 Thu Jan 26 11:55:33 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 12:05:37 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 12:10:07 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 12:13:58 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 12:15:18 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 12:20:37 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 12:25:32 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 12:38:58 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 12:46:40 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.76.76, port 53 Thu Jan 26 12:48:57 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 12:54:22 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 12:58:07 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 13:08:37 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 13:16:09 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 13:35:50 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 13:54:54 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 14:09:41 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.76.76, port 53 Thu Jan 26 14:24:34 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 14:25:47 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 14:34:35 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 14:37:45 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.76.76, port 53 Thu Jan 26 14:38:32 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 14:45:13 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 15:20:04 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 16:38:44 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 17:13:46 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.76.76, port 53 Thu Jan 26 17:14:01 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 17:15:56 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 17:20:04 2017 [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 Thu Jan 26 17:43:39 2017 - polishkazJan 27, 2017Guide
Mac's, Iphones, Smart Tv's, Playstation 4's everything loses. Going on a month now, not a single disruption to my internet with the new Modem and Router. Do yourselves a favor, buy some new equipment and let me know when that class action lawsuit happens, I'll sign on board.
