ezicefield
Jan 27, 2016Follower
C7000-100NAS randomly drops internet connection
Hello, My C7000-100NAS modem seems to randomly drop it's Comcast connection. This happen on 2.4 ghz, 5 ghz, and wired connections. There is no pattern, however the dropped connection usually last...
junfitz
Apr 06, 2017Guide
Random Dropouts keep happening on my Netgear C7000. Has this been fixed yet? Looks like this problem has been happening for quite some time now. Did Netgear finally release a fix for this? For an expensive modem/router, we expect so much more from this.
8th_Day
Apr 06, 2017Aspirant
Comcast has been on this for the last several weeks/months and can't find anything. However, their smallest test time is 5 minutes increments. But I may have stumbled on the issues. These statistics are for direct connect cable - computer to Router.
https://www.voipreview.org/speedtest
This site tests more than just upload and download speed. i tests for Latency/Ping
We use MagicJack. When we connect to a call, we loose the incoming voice for anywhere from 6 to 30 seconds. We just keep talking, though that is hard to do when it is an answering machine or robo menu. The tests explain what is happening. But I don't know where to go with this. Can't get to the right people at Comcast or Netgear.
When I ran this test the numbers in the beginning of the test were all over. It looked like an EKG and then it is steady. Something is happening at the beginning of the connection not only on the phone, but also when we go to other websites.
This was 7 PM
This was 7:15 PM
This was 7:15 PM This explains my MagicJack Phone issues
7:30 PM IP Phone and Skype are OK
- NCsandhillsApr 06, 2017Guide
is "UPnP" turned ON for both MagicJack and the Router?
Do MagicJack's settings allow selecting Incoming Ports? More than one?
These serttings will affect the performance of MagicJack, as well as other programs (Skype, etc.).
Skype's "Tools" include these types of settings. See "Tools/Options/Advanced/Connections".
- 8th_DayApr 08, 2017Aspirant
We were told to turn UPnP off for security reasons by NETGEAR. We have forwarded them manually, all of which are UDP. See below.
XXX = the dedicated ip address of Magic Jack
MagicJack Settings
# Service Name External Port External IP Address Internal Port Internal IP Address 1 MagicJackU UDP: 5060 Any UDP: 5060 192.168.1.XXX 2 MagicJackD UDP: 5070 Any UDP: 5070 192.168.1.XXX 3 MagicJack UDP: 49152 Any UDP: 49152 192.168.1.XXX 4 MagicJackRtp UDP: 65525 Any UDP: 65525 192.168.1.XXX Here are my log enteries.
Description Count Last Occurrence Target Source These are two entries I can't isolate where they are coming from. DHCP Request? But from where? To Where? None of these IP's are mine [DoS attack: IP packet w/MC or BC SRC addr] from 224.230.1.61, port 59834 1 Thu Apr 06 16:26:00 2017 65.52.108.76:443 224.230.1.61:59834 HEG US Inc. - have no idea why they would be trying to access through my router. [DoS attack: TCP- or UDP-based Port Scan] from 69.64.33.134, port 60688 1 Wed Apr 05 18:43:54 2017 My External IP:8686 69.64.33.134:60688
