ezicefield
Jan 27, 2016Follower
C7000-100NAS randomly drops internet connection
Hello, My C7000-100NAS modem seems to randomly drop it's Comcast connection. This happen on 2.4 ghz, 5 ghz, and wired connections. There is no pattern, however the dropped connection usually last...
JimPugilist
Apr 12, 2017Aspirant
did you find a solution to the problem...?? Same issue (timing sync failure) . Did reset, comcast checked----only wifi, ethernet works fine....
BigDog2017
Apr 12, 2017Guide
The C7000 was the problem. Spent a lot of time narrowing down the issue with the help of Comcast. They were very helpful, the tech even gave me his personal cell and helped with some diagnositcs off the clock. I did the typical reset, did not help. Did the factory restore...did not help. The C7000 would actually drop the WAN connection every 20 minutes. Nothing in the logs would indicate trouble, other than the Sync issues I noted earlier. Ruled out every device on the network. My only option was to replace the C7000. Netgear never responded. I will try and return it later this week because its still under warranty. Additional proof that it was the C7000, I replaced it with a Netgear CM1000 and it has been rock solid since minute one...no other changes on the network.
- JimPugilistApr 12, 2017Aspirant
itยดs a shame, but thanks!!!!
