ezicefield
Jan 27, 2016Follower
C7000-100NAS randomly drops internet connection
Hello, My C7000-100NAS modem seems to randomly drop it's Comcast connection. This happen on 2.4 ghz, 5 ghz, and wired connections. There is no pattern, however the dropped connection usually last...
dlf_texas
Jan 24, 2018Aspirant
I can also attest that using a electirical timer to power off the router once per day works.
This is considered a COLD REBOOT because you are removing power from the unit.
It is finally what I had to do and things seem to be fine most of the time.
There are still occasions when I need to do a manual REBOOT.
For a manual REBOOT you want to login to the router and do a "REBOOT" not a reset.
This is considered a WARM REBOOT because power is never actually removed from the unit.
A reset would reset the modem to factory defaults which may not be what you want.
My router has the .23 firmware but I have not removed the timer yet. This will be something I will try one day.
scsinykin
Thank you for the feedback. I've just looked around the Netgear Gateway and cannot find the place where one is able to REBOOT from the computer. I have been unplugging. My ISP says perhaps the level of my internet service (50 mg) is responsible for the dropped connections. I don't know enough about any of this to know whether that is accurate. He is recommending 100K and thinks that will resolve the issue. Does anyone have knowledge whether this is true?
- dlf_texasJan 25, 2018Aspirant
