ezicefield
Jan 27, 2016Follower
C7000-100NAS randomly drops internet connection
Hello, My C7000-100NAS modem seems to randomly drop it's Comcast connection. This happen on 2.4 ghz, 5 ghz, and wired connections. There is no pattern, however the dropped connection usually last...
Tbalfany
Nov 04, 2018Aspirant
The fix for us was change the 2.4 to channel 6 and 5ghz to channel 157 on the wireless tab of the Netgear genie ( or router login page ).
CCutter
Nov 04, 2018Tutor
Thank you for your reply! I turned it into a modem only and bought the google Wifi router, very very happy with google, not a single issue! Good luck with your solution!
