Stanzzz's avatar
Stanzzz
C7000-AC1900 intermittent internet - drops for 5-10 minutes every 2-3 hours
I have been using the Nighthawk C7000-AC1900 modem router for the last three years, and I havent had any major issues for the most part. For the last three weeks, the connection has been dropping for 5-10 mins every 2-3 hours, sometimes even more frequently. Restarts didnt help, and the firmware is up to date. ISP support asked me to talk to Netgear and trouble shoot the bands, radio etc, since I am not using their modem. I cant get Netgear support since the device is out of warranty. PLEASE HELP. :( Working from home and the connectivity issues are causing major issues at work.
  • FURRYe38's avatar
    Do wired connections also not connect when this happens?
    • Stanzzz's avatar
      Stanzzz
      Thanks for the response.
      I use channel 6 for 2.5 since 11 seems to be quite busy -> 6+ which includes two of my extendors (EX2700 and Rockspace 1200Mbps) as well. There are quite a few wifi networks in the neighbourhood and the channel assignments looks very different each time I check.
      I have channel 60 for 5, which seems to be DFS. I guess this is fine?
      I presume the wired connections have the same problem because whenever there is a wifi glitch I get the message that the Samsung smarthings hub, which is wired to the modem-roter, is disconnected too.
      By the way, yesterday night, the whole network went down for a while, and then I realized that I couldnt even find my 2.5 and 5G SSIDs. It looks like the C7000 unit somehow got reset and was transmitting the default NETGEAR SSIDs, and I had to set up the whole thing from the scratch. This has happened once before as well, a few months ago. I am not sure if this is OK or if i should be concerned (like a hack). :(
      Thank you,
      Vibin
      • FURRYe38's avatar
        Can you disable the extenders for a while and lets let if we can stablize the modem alone.
        Is there a power output setting under  Advanced Tab/Advanced Settings/Wireless Settings by chance>?
        Please channge this channel to 36 thru 48 or 149 thru 165.
        Possible the modem and WAN are going down. I know that some modems will reboot if the WAN signal goes down.
        Not this isn't a hack, more like bad modem operation. The modem should not be resetting to factory on it's own.
        Something to contact NG support about.
        olympos1625
