RobertJHales
Apr 06, 2018Aspirant
C7000 Chose to not to connect to net overnight
Woke up Tuesday morning to my C7000 Nighthawk no longer connected to the net. All cables were secure and snug, powercycled my router a few times. Went to work expecting it to magically be fixed when...
michaelkenward
Apr 07, 2018Guru - Experienced User
RobertJHales wrote:
the internet light (planet) is not on. The downstream is constant. Every so often it'll recent the downstream light and flash that before it goes solid.
That means it isn't connecting to the internet. But you knew that anyway.
Have you tried a factory reset on the thing?
There is a manual for the C7000 somewhere at the end of this link:
>>> C7000 | Product | Support | NETGEAR <<<
See page 108.
- RobertJHalesApr 08, 2018Aspirant
The tech advised it that option would only wipe my wifi settings, so I didn't do that at the time.
I went ahead and just did a factory reset on it and I am still having the same issue.
- michaelkenwardApr 09, 2018Guru - Experienced User
This thing is still under warranty. Start the return process. And don't fall for any attempts to extract money from you. That's a famous Netgear scam.
If you registered the thing in the MyNetgear on-line system, start there.
- vkdeltaApr 09, 2018NETGEAR Employee Retired
Please PM me.
- RobertJHalesApr 09, 2018Aspirant
PM Sent -- Awaiting response.
