mastergenera1
Oct 29, 2015Aspirant
C7000 modem 802.11 type exclusion?
hi i was wondering if there is any way to tighten the C7000s wifi settings to only broadcast N on the 2.4 and only broadcast AC on the 5Ghz? thanks
- Oct 30, 2015
please see page 67
http://www.downloads.netgear.com/files/GDC/C7000/C7000_Comcast_UM_27apr15.pdf
please change 2.4G 289 Mbps
for 5GHz, you can 600 Mbps or even lower.
mastergenera1
also i wanted to say that i live in an apt complex so any way i can enhance the ability of the radios with settings. id like to have as many options as possible, my old ISP assigned mdm was a technicolor 8715D, and it had the functionality i speak of, but just failed 2x in 3 months, wasnt gonna have it and wanted my own unit. so i bought quality.
- vkdeltaOct 30, 2015NETGEAR Employee Retired
do you want to increase the power?
easy way to reduce from HT80 to H20 which will slightly boost up power at the expense of bandwidth.
- mastergenera1Oct 30, 2015Aspirant
So which menu is that under?
please see page 67
