kkrathi
Sep 11, 2015Follower
C7000 NIGHTHAWK MODEM AND ROUTER - WHERE TO DISABLE AP ISOLATION FOR CHROMECAST?
I am not able to connect chromecast. I keep getting a message that I am supposed to disable AP isolation mode. I checked manual and the wireless setting and I can't find anything straight forward tha...
DarrenM
Sep 14, 2015Sr. NETGEAR Moderator
Hello KKrathi
There isn't a option to disable AP isolation on this modem but make sure your not connecting the guest network they usually have that enable on a guest network. The other thing I would do is try a factory reset of the chromecast and try to connect again. here is a article on how to reset it.
http://www.tomsguide.com/us/factory-reset-google-chromecast,news-18294.html
DarrenM
