blizzzzzzzzzard
May 16, 2016Follower
C7000 Readyshare not working on Macbook, Xbox One - WD 1TB My Passport
C7000 Nighthawk cable modem and router 2008 Macbook with latest El Capitan update, 10.11.4, 5ghz WiFi connection to router Xbox One, cat5e ethernet cable connection to router 1 TB WD My Passport, ...
DarrenM
May 23, 2016Sr. NETGEAR Moderator
Hello Blizzard
Before putting files onto the drive did you format the drive it could be some software that is preloaded on the drive that could be causing the issues.
DarrenM
