blizzzzzzzzzard
May 16, 2016Follower
C7000 Readyshare not working on Macbook, Xbox One - WD 1TB My Passport
C7000 Nighthawk cable modem and router 2008 Macbook with latest El Capitan update, 10.11.4, 5ghz WiFi connection to router Xbox One, cat5e ethernet cable connection to router 1 TB WD My Passport, ...
foxinsox60
Jun 04, 2016Aspirant
Hi DarrenM, do you know what the limit is to how much can be shared across Readyshare? Also, is the formatting or software preloaded on the drive having issue with the router or the computer accessing it? Thanks!
DarrenM
Jun 06, 2016Sr. NETGEAR Moderator
Hello foxinsox60
There should be no limit on how much you can share and preloaded software can be a issue so you do want to make sure you have formatted the drive before setting it up with Readyshare.
DarrenM
