bschmiedeler
Oct 16, 2019Aspirant
C7000 Router Modem dropping WiFi periodically on Mac OS X Catalina
Hello,
I have been battling this issue for about 2 months or so.
I have a C7000 Nighthawk Cable Modem Router. Firmwire is V1.01.32. Compure is a 2017 MBP running Mac OS X 15.0 Catalina.
The WiFi is not stable. When I reboot the Router I can connect to either of my two networks (one is ac and the other is b/g/n) and the speed is good (maybe 150Mbps on the b/g/n).
I have
1. Reset the router (once).
2. Rebooted numerous times.
3. I have not changed the cable.
4. I have not reflash firmware or done factory reset. Open to doing this.
Isn't there some log somewhere where I can look and see what is going on?
Thanks,
Bryan
Do you know if you were having wifi problems before OSX 10.15?
Any Wifi Neighbors near by? If so, how many?- bschmiedelerAspirant
Approximately, yes. I started running Catalina betas in late July. However, I don't think that is the issue, as I have a work MBP which I have NOT upgraded, and it still suffers from these problems. Also, our iDevices will sometimes have issues as they of course prefer WiFi over cellular. Sometimes if I am on my iPhone or iPad elsewhere in the house network speed will start to go south and I turn off WiFi and go to cellular and speeds are great.
However, I manage the router from the Mac that is running Catalina and was running the Bets. I have not tried connecting my home MBP directly to the router as I need a USB-C to ethernet converter.
5Ghz is manually set to 153.
2.4Ghz was auto but manually changed it to 11.
Too many. Not neighbors really, but devices. I am using Netspot to moniter WiFi (see attached picture). However, things were running very well for about 18 months, WiFi just worked. No idea what the heck happened.
Should I try a full factory reset?
Thank you for your suggestions. Looking at this as a learning experience.+
I would factory reset and setup from scratch.
ALso turn OFF all other wifi devices that put out a wifi signal temporarily to see if this helps resolve problems.
