hlfox17's avatar
hlfox17
C7000 Smaller Power Brick
The power plug is too big for the location I am trying to move my router modem to. Is there a smaller plug that will work with my C7000 Router Modem? I cannot believe in this day and age that big plugs are still a thing. Thanks for any help you can send my way.
  • > The power plug is too big for the location I am trying to move my
    > router modem to. [...]
       Not a very detailed description of that problem.  If the actual
    problem is a too-crowded outlet strip, then I's get a cheap extenstion
    cord (with a smaller plug).
    > [...] I cannot believe in this day and age that big plugs are still a
    > thing. [...]
       Why not?  Define "big".
       The ratings should be printed on the adapter and the C7000, and
    should be found in the User Manual, too.  Shop around, if you want.
    • hlfox17's avatar
      hlfox17
      Trying to put the plug into a built in wall outlet and then put a second plug in the other socket. Problem is, once I put in this large power brick, there is not room for the other plug. I am trying to hide as much as possible so an extension cord just worsens the problem .
      • antinode's avatar
        antinode
        Guru
        > [...] I am trying to hide as much as possible so an extension cord
           Get/make a shorter extension cord?  With my weak psychic powers, I
        can't see any of the stuff which you're not describing very well.  You
        seem to have a home-improvement problem, not a modem+router problem, so
        this might not be the best forum for it.
           Previous advice still applies.
              https://en.wikipedia.org/wiki/Shop_Around
