DashWilliams27
Apr 15, 2020Tutor
C7000 Speed drop Newly added to Suddenlink plan
Just purchased a C7000 AC1900 Nighthawk. Had the modem activated on my Suddenlink account and I can not get more than 20 down and 2 up. I confirmed the old modem was taken off of the account (tested ...
Apr 16, 2020Guru - Experienced User
1. is the C7000 approved for gigabit on suddenlink?
2. did they provision it correctly? it wouldn't be the first time the wrong provisioning has been sent
3. have they checked your line? you upstream signal is low. If there's any attenuators, splitters, amplifiers in line, remove them.
- DashWilliams27Apr 16, 2020Tutor
As i look into it more, it seems you need a 32X8 for Gigabet speed, but shouldn't i still get 500Mbps? and I have called them mulitple times to check the cose sent to the modem to insure it is the coorct one and they have assured me it is. I have no equipment between the port and the modem I am just getting terribly slow speed. 20 down and 2 up. Suddenlinks Gig plan only offers 52 up as its max.
- plemansApr 16, 2020Guru - Experienced User
so its either:
1. the line from the isp.
2. the provisioning sent to it.
3. the C7000
Its tough when you dont' know and can't prove. do you have a spare modem you can try or will the isp give/lease you one? I've had to lease one once for a month to prove to an ISP that it wasn't my modem causing the slowdowns. They're much more liable to work on a line when their equipment isn't performing.
- DashWilliams27Apr 17, 2020Tutor
It wasn't the line. I'm not sure if it was the provisining or the C7000, but I bought the CM1000 which is rated for a Gigabit, had it acctivated and I had the exact same issue, talked to a tech and he sent a refresh code now the issue is fixed. A part of me wants to add the C7000 back and have them send a refresh code just to see what happenes, but at this point I am just happy to have my speed back. Luckily I already had 6 Eero mesh routers because the CM1000 does not have a built in router.
