DashWilliams27
Apr 15, 2020Tutor
C7000 Speed drop Newly added to Suddenlink plan
Just purchased a C7000 AC1900 Nighthawk. Had the modem activated on my Suddenlink account and I can not get more than 20 down and 2 up. I confirmed the old modem was taken off of the account (tested ...
DashWilliams27
Apr 16, 2020Tutor
As i look into it more, it seems you need a 32X8 for Gigabet speed, but shouldn't i still get 500Mbps? and I have called them mulitple times to check the cose sent to the modem to insure it is the coorct one and they have assured me it is. I have no equipment between the port and the modem I am just getting terribly slow speed. 20 down and 2 up. Suddenlinks Gig plan only offers 52 up as its max.
Apr 16, 2020Guru - Experienced User
so its either:
1. the line from the isp.
2. the provisioning sent to it.
3. the C7000
Its tough when you dont' know and can't prove. do you have a spare modem you can try or will the isp give/lease you one? I've had to lease one once for a month to prove to an ISP that it wasn't my modem causing the slowdowns. They're much more liable to work on a line when their equipment isn't performing.
