DashWilliams27
Apr 15, 2020Tutor
C7000 Speed drop Newly added to Suddenlink plan
Just purchased a C7000 AC1900 Nighthawk. Had the modem activated on my Suddenlink account and I can not get more than 20 down and 2 up. I confirmed the old modem was taken off of the account (tested ...
DashWilliams27
Apr 17, 2020Tutor
It wasn't the line. I'm not sure if it was the provisining or the C7000, but I bought the CM1000 which is rated for a Gigabit, had it acctivated and I had the exact same issue, talked to a tech and he sent a refresh code now the issue is fixed. A part of me wants to add the C7000 back and have them send a refresh code just to see what happenes, but at this point I am just happy to have my speed back. Luckily I already had 6 Eero mesh routers because the CM1000 does not have a built in router.
Apr 17, 2020Guru - Experienced User
I'd suspect you're right on the provisioning being the issue. Especially when they had to send it 2x to get the cm1000 working properly.
Really makes you suspect their setup department.
I'm glad to hear you got it functing though! I've had a cm1000 since they came out and its ran great for me. Hope you have the same luck.
- michaelkenwardApr 17, 2020Guru - Experienced User
If you need more help, you might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Cable Modems & Routers
