mscruggs's avatar
mscruggs
Follower
Sep 26, 2020
C7000
Internet light keeps flashing, spectrum says it's a router issue. Modem is 4 months old. NETGEAR tech support wants to charge me to reconfigure the modem, unbelievable. Does anyone know how to reconfigure this this product. Thanks in advance.
  • plemans's avatar
    Do you have a screen snip of the cable connections page and logs?
    Please take that and post them back here.
    Also, if you have any splitters, amplifiers, attenuators in line, remove them.
  • Hey, I have the same issue with Spectrum.  They are telling me its my router.  My router shows an excellent signal.  They want me to buy their equipment.  I wish i knew what to do.  They wont fix the issue with my wifi. The tech came out and said there was a problem on the pole and they are saying their is no problem and that its my equipment that is failing.  I know that is not the case.  Any help here guys?
    • plemans's avatar
      kozyjozie try starting your own thread and we're happy to help.
      Include the modem cable connections page and the logs for us to check.
