Starblerc
Jan 25, 2019Aspirant
C7000V2 - Call of Duty Open NAT 2 PS4 simultaneously
Hello,
I tried contacting Netgear customer support and had a terrible experience. So here's my issue
I have two systems, whether it be ps4 and ps4 or ps4 and PC, and I want to play Call of Du...
Starblerc
Wish that was possible. Activision (Call of duty) only uses certain ports. After contacting their tech support, their solution was to hook the second system up to a different network.
Starblerc
| Platform | TCP Ports | UDP Ports |
| PC | 3074, 27014-27050 | 3478, 4379-4380, 27000-27031, 27036 |
| PlayStation 4 | 80, 443, 1935, 3478-3480 | 3478-3479 |
| Xbox One | 53, 80, 3074 | 53, 88, 500, 3074, 3075, 3544, 4500 |
- michaelkenwardJan 26, 2019Guru - Experienced User
If you have the C7000V2 you might get better replies, and find other answers, over in the appropriate section:
Cable Modems & Routers
