Esha2012
Nov 20, 2021Aspirant
C7000V2 - Need "Ethernet Connection" as Input to Cable modem/router instead of Coaxial cable
Dear Friends, I had purchased the cable router modem(C7000V2) in 2019 in US & which has "Coaxial Cable" as Input. I carried this to another country as part of relocation. In my country we have ether...
michaelkenward
Nov 21, 2021Guru - Experienced User
Esha2012 wrote:
Dear Friends,
I had purchased the cable router modem(C7000V2) in 2019 in US & which has "Coaxial Cable" as Input. I carried this to another country as part of relocation. In my country we have ethernet connection as the Input & not cable input.
There is no option to use a cable modem/router in router only mode.
DSL modem/routers do have the WAN ethernet port on the back needed for this feature. .
Solved: Re: CAN NIGHTHAWK AC1900 C7000V2 WIFI CABLE MODEM ... - NETGEAR Communities
Solved: How to make a cable modem into a router - NETGEAR Communities
That's just a couple of messages that confirm that you have a useless device.
If you want to confirm this with someone who owns a cable modem/router, you might get more help in the appropriate section for your hardware.
Cable Modems & Routers
- Esha2012Nov 21, 2021Aspirant
Thanks for the quick response Guru & Appreciate it. I thought converter(Coaxial to RJ45) may work & now found that it is not possible option.
- michaelkenwardNov 21, 2021Guru - Experienced User
Esha2012 wrote:
I thought converter(Coaxial to RJ45) may work ....
Afraid not. Completely different signals.
Thanks for clarifying & sharing this information.
