laumansm
Nov 06, 2022Aspirant
c7000v2 in bridge mode but wifi is still on
Hi there, I have placed my Netgear c7000v2 cable modem / router into bridge mode ie I turned routing functions off. A downstream tp-link router takes over routing and wifi duties. However, even in bridge mode, the c7000 keeps turning wifi back on. Only the 5 Ghz channel, not the 2.4. There is no facility in bridge mode to turn the wifi off or on manually. After a reboot, wifi is off but then turns back on. The problem is that this interferes with the wifi that the TP link provides. There is also a manual wifi off/on button in the front of the device. The manual says to push this button for 2 secs to turn wifi off. I tried 1 sec, 2 secs and 10 secs but it makes no difference. The wifi stays on.
I don't think that should be happening in bridge mode, correct? How can I turn wifi off on the c7000 when in bridge mode?
Thank you so much!
- laumansmAspirantEdit: I noticed that OneMesh was on on my TP-Link router. I turned it off then rebooted the Netgear cable modem and, one hour into it, the wifi stays off. Fingers crossed.
- KitsapMaster
 laumansm wrote:Hi there, I have placed my Netgear c7000v2 cable modem / router into bridge mode ie I turned routing functions off. A downstream tp-link router takes over routing and wifi duties. However, even in bridge mode, the c7000 keeps turning wifi back on. Only the 5 Ghz channel, not the 2.4. There is no facility in bridge mode to turn the wifi off or on manually. After a reboot, wifi is off but then turns back on. The problem is that this interferes with the wifi that the TP link provides. There is also a manual wifi off/on button in the front of the device. The manual says to push this button for 2 secs to turn wifi off. I tried 1 sec, 2 secs and 10 secs but it makes no difference. The wifi stays on. I don't think that should be happening in bridge mode, correct? How can I turn wifi off on the c7000 when in bridge mode? Thank you so much! The second LED from the bottom is a combination indicator/switch. To turn off the Wi-Fi radios, press and hold for two seconds before releasing. See attached. If you have not done so, go to the Downloads section above and download the manual. - laumansmAspirantThe second LED from the bottom is a combination indicator/switch. To turn off the Wi-Fi radios, press and hold for two seconds before releasing. See attached. If you have not done so, go to the Downloads section above and download the manual.
 Yes, i have tried that, too but it didn't seem to make any difference. Wifi stayed on. Thanks!- KitsapMaster
 laumansm wrote:The second LED from the bottom is a combination indicator/switch. To turn off the Wi-Fi radios, press and hold for two seconds before releasing. See attached. If you have not done so, go to the Downloads section above and download the manual.
 Yes, i have tried that, too but it didn't seem to make any difference. Wifi stayed on. Thanks!I find it very difficult to believe your C7000v2 Wi-Fi is still transmitting when the Wi-Fi radio indicator on the front panel is not illuminated. Do you have unique SSID's configured for both the 2.4 and 5 GHz Wi-Fi bands on your C7000v2? Do you have any other devices in the home that transmit Wi-Fi signals with the same SSID's? What client device are you using to determine the C7000v2 Wi-Fi is still transmitting?
- FURRYe38Guru - Experienced UserI would make contact with NG support and let them know what your seeing. Saw similar issue with a CBR750.
