Mystery123's avatar
Mystery123
C7000v2 internet speed dropped after reconnecting ethernet cable, wifi is still fast.
So I had to move the location of the mode/router and afterwards, direct connection speed is very slow.
I was getting 200mbps before and now it caps at around 93mbps.
I tried different cables, the same cable that showed 200mbps before but all are now around 90 - 93 mbps range.
I also tried a different computer hard wired and that also shows around 90 mbps but same computer with wifi adapter shows 200 mbps.
What happened by just unplugging the wires?
So weird.
Edit: BTW one thing that's different now is the light by the ethernet cable.
Before, it had green but now it's orange / amber with the same cable, same or any port and same computer.
  • FURRYe38's avatar
    Be sure your ethernet adapter is supporting of 1000Mbps and not 100Mbps.
    Update the ethernet adapter drivers.
    Try a different ethernet adapter.
    Be sure your using a good quality LAN cable between the modem and PC. CAT6 is recommended.
    So weird.
    Edit: BTW one thing that's different now is the light by the ethernet cable. <What Ethernet cable? Where do you see this?
