JD22
Jul 10, 2022Aspirant
C7000v2 keeps loosing connection
Modem keeps loosing connection 3-5 times an hour. The nighthawk app, about every 20 seconds, show the following message "Your cable modem router is not connected or activate". I reset the modem about...
Jul 11, 2022Guru - Experienced User
Do you have a screensnip of the cable connections page and the event logs?
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
JD22
Jul 11, 2022Aspirant
The modem is connected directly to the cable that leads outside. I check the cables and there are no wear and tear. They look fine to me.
I get the following code now
WiFi Interface [wl0] set to Channel 1 (Side-Band Channel:N/A) - Reason:INTERFERENCE
WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INTERFERENCE
but before the above I would get the following:
No Ranging Response received - T3 time-out;
WiFi Interface [wl1] set to Channel 153 (Side-Band Channel:N/A) - Reason:INIT
WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INIT
SYNC Timing Synchronization failure - Failed to acquire FEC framing;
power logs are as follows from the attachment
