JD22
Jul 10, 2022Aspirant
C7000v2 keeps loosing connection
Modem keeps loosing connection 3-5 times an hour. The nighthawk app, about every 20 seconds, show the following message "Your cable modem router is not connected or activate". I reset the modem about...
Jul 11, 2022Guru - Experienced User
Do you have a screensnip of the cable connections page and the event logs?
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
JD22
Jul 11, 2022Aspirant
- plemansJul 11, 2022Guru - Experienced User
Got the cable connections page but need the event logs. Not just the "logs".
The event logs show the cable connections page issues over a longer period. the cable connections page is just a quick snap shot from when you opened the page.
- JD22Jul 11, 2022Aspirant
attached is the cable connection page. I don't see anything with Event logs in it. Apologies I am not following.
- plemansJul 12, 2022Guru - Experienced User
thats the cable connections page.
The combo devices have a log and an event log. One shows the router side details and the other the modem side. The event log is what's needed to help with checking the modem's long term connection
