JD22
Jul 10, 2022Aspirant
C7000v2 keeps loosing connection
Modem keeps loosing connection 3-5 times an hour. The nighthawk app, about every 20 seconds, show the following message "Your cable modem router is not connected or activate". I reset the modem about...
Jul 12, 2022Guru - Experienced User
It looks clear today. You initially had a few requests from the cmts to reset/reboot it on the 7/10 date. "thats the docsdevresetnow" notice.
When it first boots up, its normal to see a couple sync/timing errors but not once its running.
