map6429
Nov 07, 2022Follower
C7000v2 keeps resetting itself - issue resolved
I recently swapped from a C6300 to a second hand C7000v2 due to the Intel Puma 6 chipset issue. The C7000v2 improved internet performance, but the modem/router itself wouldn't stay on reliably. It ke...
Nov 08, 2022Guru - Experienced User
According to the manual, its supposed to have a 3.5a 12v power supply.
Whoever you bought it from probably sent you the wrong one.
More than likely they were having issue with it and probably why they sold it 🙂
see it all the time where someone accidentally uses a modem power supply on the router and it doesn't supply enough amps to run it.
