Kyle136's avatar
Kyle136
Follower
Jul 21, 2019
C7000v2 no lights on at all
Power went out at my house during a storm and the WiFi went down as well. When I checked the router there were no lights on in any color on the box. When I plug/unplug the router the power light flashes red once and then goes out like the rest of the lights.
Yes, it is hooked to a surge protector and all the other devices plugged into the same surge protector are running normally. Also yes, I have tried resetting it as the manual proscribes and nothing changed.
Thank you in advance for your input!
  • michaelkenward's avatar
    michaelkenward
    Kyle136 wrote:
    Power went out at my house during a storm ...
    Storms are a great way of killing electronic equipment.
    If you have overhead telephone cables, they can get hit by lightning strikes that send a nasty jolt into a modem. I lost a bunch of kit like that once.
    If the suggestion from microchip8 doesn't work, then you may be stuffed.
