MitchT
Aug 22, 2019Aspirant
C7000v2 Router reset and now shows factory network names and passwords
I came home and noticed my internet was out. I expected it was a Cox issue. An hour later, and after all the fixes from the Cox rep. didn't work they determined it was likely a setting on my router. I plugged in to the admin area of the router and noticed the network names for 2 and 5 G had switched back to Netgear75 wireless network name and passwords. I've had this router for one year and this has never happened. What would prompt the router to do this?
Your subject says C7000v2, that's a cable modem/router. Your footer says A7000. (That's a WiFi USB Adapter.)
Your message appears in Nighthawk WiFi Routers. That's something else altogether.
You might get better and quicker replies, and find other answers, over in the appropriate section:
Cable Modems & Routers
