bolthead28
Aug 11, 2022Initiate
c7000v2 Slow wifi speed
I have the same issue as you "Slow download wifi speed on C7000v2". I initially have the Netgear c3700v2 modem router combo (Handles up to 300Mbps each on the 2.4 and 5G bands). Since I have switch...
Aug 11, 2022Guru - Experienced User
"But Wifi is only around 270 Mbps." This is pretty good and around the top range that you seen on 5Ghz AC wifi. Most devices top out at around 300-500Mpbs. You'll not see anywhere near 900Mpbs on 5Ghz WiFi on this model modem.
- plemansAug 11, 2022Guru - Experienced User
