TexasAxMan
Mar 24, 2023Aspirant
C7000v2 suddenly won't connect
I've contacted Xfinity and they say there is no issue on their end.
Last night everything worked. This morning, not.
I'm able to get to the internet with my laptop (connected wirelessly). My Echos and Firesticks won't connect up though.
All lights are green, the 2.4 Ghz and 5 Ghz lights flash.
Has a power off for 1 minute then back ON with the modem been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-routerBe sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html- TexasAxManAspirant
When I try either of those I get this:
Also, I have rebooted several times.
