nickg10
Nov 29, 2023Aspirant
C7000v2 Very Slow Wifi
I've read a ton of threads on this issue but not many with a solution.
My internet plan is for 300mbps. I can achieve 290-315mbps with a wired connection.
However, the fasted speed I've seen over wifi is 50-60mbps with the 5GHz connection and only 2mbps on 2.4GHZ. This is common across my iPhone 13 Pro and a Dell Precision 5770 laptop. I have no issues getting 400+mbps when I am on wifi at work so I don't think it's an issue with the devices I am using.
I've tried different channels with negligible improvements. Are there other settings I should be looking into to improve the speed?
The C7000 should be able to achieve faster speeds. I've used one and it was fine.
Try a factory reset. During the install, just install with the defaults and test the speeds.
Leave any qos, access control, traffic monitoring, or parental controls disabled.
