mntimmons
Jun 05, 2019Aspirant
C7000v2 Xbox One setup
Hello I am trying to get the best setup for XBOX One with the Nighthawk AC1900 C7000v2 and am unable to set up QoS to give my Xbox priority. I have logged into the router and tried to find QoS but c...
mntimmons
It is wireless. I have searched up and down and I do not believe there is QoS.
Jun 05, 2019Guru - Experienced User
Whats the distance between the modem and xbox?
Can you test the xbox wire connected to the modem to see if game performs better?
What wirelss Up To modes and channels is the modem using?
Try setting manual channels, 1, 6 or 11 on 2.4Ghz and any unused channels on 5Ghz.
Ensure any beamforming and WMM if seen in the UI, is enabled.
