lyanes
Oct 15, 2019Aspirant
c700v2 - no disk in advanced>USB Storage>Advanced settings
Hello, I am attempting to setup my c700v2 with a network folder. However, when I go to>advanced>USB Storage>Advanced settings, there is no device listed in "Available Network Folders" section. Ev...
Oct 15, 2019Guru - Experienced User
I take it you meant the C7000v2? You put c700v2.
I didn't find the hard drive you leasted on the compatible drives listing.
https://kb.netgear.com/18985/Will-my-USB-drive-work-with-ReadySHARE
Doesnt' mean it won't work but I haven't seen much luck with usb drives greater than 3-4Tb.
- lyanesOct 15, 2019Aspirant
Yes, its the c7000v2. Thanks!
Right, so now I'm wondering how do we get this to work properly from the Netgear side.
- plemansOct 15, 2019Guru - Experienced User
Well, this is the community forum. Members of the public helping others out. Not much we can do from the community forum. many people have requested improvement to the compatibility of the drives that readyshare can use. This is on the ideas exchange forum. here's just one for instance.
