bnichols
May 02, 2017Guide
C7100V and parental controls/dns settings
Netgear C7100V Cable modem/router with voice. Parental controls don't work. Furthermore, if I manually enter OpenDNS as the IPv4 servers, it also doesn't work. It appears that this modem has th...
bnichols
May 12, 2017Guide
Thanks DarrenM,
I'm sure your solution works but is not entirely accurate. My problem occurred because I had an extender (on AP mode) using the same SSID and password as the modem/router. Changing the extender to a unique SSID fixed the problem and I am able to use parental controls successfully with the C7100V. I did not need to make any changes to the client's IPv6 settings.
bnichols
Jul 16, 2017Guide
Follow-up on this thread.
The c7100v indeed has a bug that does not allow custom IPv4 DNS settings - it will always override them with Comcast's IPv6 servers. So if you want to customize your DNS settings don't get this router. I have been through both Netgear and Comcast/Xfinity support with no resolution. The slightly good news is that if you choose to use Parental Controls (and like OpenDNS), enabling that will still work to filter your web content for your network.
