SC_Stigmata
Oct 26, 2020Tutor
C7100V cable modem/router will not recognize external USB device
Modem/Router doesn't recognize external HD. This seems to be an issue with this model. Previous solutions (replace until you get one that works) and power cycle (reset) and hope that works. Any ot...
Oct 26, 2020Guru - Experienced User
What is the mfr and model of the external USB drive?
Drive size?
Does this drive have its own power source?
- SC_StigmataOct 26, 2020Tutor
Hello, I've tried two. They are both WD My Passport. Both are less than 3 years old. One is a 1T and the other 2T. Neither have their own power source. They both are powered through the USB connection. That was one concern I had. Maybe it requires external pwr.?
- FURRYe38Oct 26, 2020Guru - Experienced User
Some larger sized drives need more port than what modems and routers can provide.
However to test this out, find a small usb flash drive and connect it to the modem, is it seen by the modem at all? Anything from 8Gb to 64Gb usb flash drive should work.
- plemansOct 27, 2020Guru - Experienced User
What format are they in?
The router supports the following file system types for full read/write access:
- FAT16, FAT32
- NTFS
- NTFS with compression format enabled
- Ext2, Ext3, Ext4
- XFS
- HFS
- HFS+
- SC_StigmataOct 27, 2020Tutor
Well, that could be my problem. The two HD's I tried are Mac OS Extended (Journaled). The thumbdrive I tried (32 Gb) to make sure it wasn't a HD size issue is APFS. I will try format a thumb drive with FAT16 or FAT32 and give it a try.
