Mopedlady
Feb 26, 2018Follower
C7100v compatible harddrives?
Hi, I have a C7100v cable modem router. I can't find an external hdd that is compatible with Readyshare.. There is a compatibility list for the C7000--will those drives work with the C7100v?
1 Reply
- vkdeltaNETGEAR Employee Retired
yes, most of the drives will work. Ideally choose lower TB/GB, since higher TBs have problems to work with routers/gateways.
