2ndstringroadie
Aug 23, 2017Follower
C7100v Netgear Genie Remote connection
I just bought a C7100v modem/AC1900 router. I can get the Netgear Genie app to connect locally, but having issues with the remote connection. Turned on the remote connection on the web portal. Tri...
DarrenM
Aug 25, 2017Sr. NETGEAR Moderator
You may want to check page 105
http://www.downloads.netgear.com/files/GDC/C7100V/C7100V_UM_EN.pdf
DarrenM
