XboxOneUser's avatar
XboxOneUser
C7100v refuses to disable UPnP
I've tried four times and I'm sure after this post goes up I will have tired several more times.
I go to advanced settings to the upnp tab then uncheck the box that says turn upnp on and click apply. The router immediately shuts down then reboots and upnp is back online like nothing ever happened. At this point I might as well just use that as a reboot feature because it takes much less time than manually rebooting the router. This is incredibly frustrating and I have no idea what to do.
I'm trying to disable UPnP because I have my console in the DMZ server so I have no use for it and I theorize that upnp is actually making my experience considerably worse
Hardware version says 2.00
Firmware version: V2.01.45
