stevesous
Oct 07, 2018Aspirant
C7800 bridge mode
Hi ,
I am having problems with my C7800 modem/router.
I can't seem to find the Bridge mode?
Can someone help?
Thank you
antinode
Oct 07, 2018Guru
I don't see it in the User Manual. Why do you want this?
stevesous
I had to move my router next to my computer, so i can have a wired connection. Now there are dead spots in my house and weak connections.
I want to get a mesh network, so i want to turn off the wireless on my router/modem.
- antinodeOct 09, 2018Guru
> connection. [...]
So, presumably, running an Ethernet cable from the old location of
the C7800 to this computer was not convenient? (There exist Powerline
devices which can use the building electrical wiring to emulate an
Ethernet cable.)
> [...] i want to turn off the wireless on my router/modem.
That you can do. Visit http://netgear.com/support , put in your
model number, and look for Documentation. Get the User Manual. Look
for "Control the WiFi Radios". But, even if you do that, it will still
be a router.
> [...] I want to get a mesh network, [...]
Why not leave the C7800 as it is, and add a wireless access point or
an extender?- vkdeltaOct 09, 2018NETGEAR Employee Retired
user manual page 14:
http://www.downloads.netgear.com/files/GDC/C7800/C7800_UM_EN.pdf
Connect Your Modem Router to a Router After Installation and Activation During the installation and activation, you must connect the modem router directly to a computer. After installation and activation, you can connect the modem router to a router. If you want to connect your modem router to a router, you must disable NAT. With NAT disabled, to avoid conflicting with the other router on the network, the modem router does not use NAT. To disable NAT and connect your modem router to a router after installation and activation: 1. Launch a web browser from a computer or mobile device that is connected to the modem router network. 2. Enter http://routerlogin.net or http://192.168.0.1. A login window opens. 3. Enter the modem router user name and password. The user name is admin. The default password is password. The user name and password are case-sensitive. The BASIC Home page displays. 4. Select ADVANCED > Advanced Setup > NAT Mode. The NAT page displays. 5. Clear the Turn NAT On check box. 6. Click the Apply button. Your settings are saved. 7. Follow the instructions that came with your router or gateway to connect it to the modem router
