Soul22's avatar
Soul22
Tutor
Jan 06, 2021
C7800 errors and disconnects
Log code says: critical 3 Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b4:62:48;CMTS-MAC=00:a3:d1:5d:61:5b;CM-QOS=1.1;CM-VER=3.1;
What on earth does that mean?
  • There’s more....
    Time Priority Description
    2021-01-06, 22:10:58 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b4:62:48;CMTS-MAC=00:a3:d1:5d:61:5b;CM-QOS=1.1;CM-VER=3.1;
    2021-01-06, 22:10:58 Warning (5) MDD message timeout;CM-MAC=44:a5:6e:b4:62:48;CMTS-MAC=00:a3:d1:5d:61:5b;CM-QOS=1.1;CM-VER=3.1;
    2021-01-06, 22:10:45 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b4:62:48;CMTS-MAC=00:a3:d1:5d:61:5b;CM-QOS=1.1;CM-VER=3.1;
    2021-01-06, 22:10:31 Warning (5) MDD message timeout;CM-MAC=44:a5:6e:b4:62:48;CMTS-MAC=00:a3:d1:5d:61:5b;CM-QOS=1.1;CM-VER=3.1;
    2021-01-06, 21:48:05 Warning (5) Unicast DSID PSN startup error
    2021-01-06, 21:48:02 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=44:a5:6e:b4:62:48;CMTS-MAC=00:a3:d1:5d:61:5b;CM-QOS=1.1;CM-VER=3.1;
    2021-01-06, 21:39:13 Warning (5) MDD message timeout;CM-MAC=44:a5:6e:b4:62:48;CMTS-MAC=00:a3:d1:5d:61:5b;CM-QOS=1.1;CM-VER=3.1;
    2021-01-06, 21:35:52 Warning (5) Dynamic Range Window violation
    2021-01-06, 21:35:49 Notice (6) TLV-11 - unrecognized OID;CM-MAC=44:a5:6e:b4:62:48;CMTS-MAC=00:a3:d1:5d:61:5b;CM-QOS=1.1;CM-VER=3.1;
    2021-01-06, 21:35:49 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=44:a5:6e:b4:62:48;CMTS-MAC=00:a3:d1:5d:61:5b;CM-QOS=1.1;CM-VER=3.1;
    2021-01-06, 21:35:43 Notice (6) Honoring MDD; IP provisioning mode = IPv4
    2021-01-06, 21:35:29 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=44:a5:6e:b4:62:48;CMTS-MAC=00:a3:d1:5d:61:5b;CM-QOS=1.1;CM-VER=3.1;
    2021-01-06, 21:35:18 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=44:a5:6e:b4:62:48;CMTS-MAC=00:a3:d1:5d:61:5b;CM-QOS=1.1;CM-VER=3.1;
    2021-01-06, 21:35:18 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=44:a5:6e:b4:62:48;CMTS-MAC=00:a3:d1:5d:61:5b;CM-QOS=1.1;CM-VER=3.1;
    2021-01-06, 21:32:33 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b4:62:48;CMTS-MAC=00:a3:d1:5d:61:5b;CM-QOS=1.1;CM-VER=3.1;
    • michaelkenward's avatar
      michaelkenward
      You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
      You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
      Cable Modems & Routers
      I will ask the Netgear moderator to move your message.
      • plemans's avatar
        also, screen snips are easier to read.
        I'd also get a snip of the cable connections page.
