Metallicacloud9's avatar
Apr 23, 2021
c7800 losing connection
Hello all,
I have a c7800 router and it had previously been working fine. Over the past couple months I have been getting intermittent dropouts. It typically is fixed by unplugging and rebooting the router. When I pull up the error logging from my router's gateway, here are the lines I got for the latest disconnect. I plan on calling the ISP to have a tech come out and check the lines as well as try to get them to push any firmware updates since I cannot update it through the gateway myself (My current firmware is V3.01.36 and I know that is old, but there isn't a specific listing for my ISP [Atlantic Broadband]). However, I am not the most familiar with this so I was wondering if anyone sees the problem directly with these error messages. Thanks for any help!
2021-04-23, 09:27:11.0
Critical (3)
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=78:d2:94:ff:07:40;CMTS-MAC=d4:2c:44:7d:1a:ae;CM-QOS=1.1;CM-VER=3.1;
2021-04-23, 09:27:20.0
Critical (3)
No Ranging Response received - T3 time-out;CM-MAC=78:d2:94:ff:07:40;CMTS-MAC=d4:2c:44:7d:1a:ae;CM-QOS=1.1;CM-VER=3.1;
2021-04-23, 09:27:24.0
Critical (3)
2021-04-23, 09:27:33.0
Critical (3)
No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=78:d2:94:ff:07:40;CMTS-MAC=d4:2c:44:7d:1a:ae;CM-QOS=1.1;CM-VER=3.1;
2021-04-23, 09:27:39.0
Critical (3)
Time Not Established
Critical (3)
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=78:d2:94:ff:07:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Notice (6)
Honoring MDD; IP provisioning mode = IPv4
Warning (5)
DHCP WARNING - Non-critical field invalid in response ;CM-MAC=78:d2:94:ff:07:40;CMTS-MAC=d4:2c:44:7d:1a:ae;CM-QOS=1.1;CM-VER=3.1;
2021-04-23, 09:29:51.0
Error (4)
Missing BP Configuration Setting TLV Type: 17.1;CM-MAC=78:d2:94:ff:07:40;CMTS-MAC=d4:2c:44:7d:1a:ae;CM-QOS=1.1;CM-VER=3.1;
Error (4)
Missing BP Configuration Setting TLV Type: 17.2;CM-MAC=78:d2:94:ff:07:40;CMTS-MAC=d4:2c:44:7d:1a:ae;CM-QOS=1.1;CM-VER=3.1;
Error (4)
Missing BP Configuration Setting TLV Type: 17.3;CM-MAC=78:d2:94:ff:07:40;CMTS-MAC=d4:2c:44:7d:1a:ae;CM-QOS=1.1;CM-VER=3.1;
Error (4)
Missing BP Configuration Setting TLV Type: 17.4;CM-MAC=78:d2:94:ff:07:40;CMTS-MAC=d4:2c:44:7d:1a:ae;CM-QOS=1.1;CM-VER=3.1;
Error (4)
Missing BP Configuration Setting TLV Type: 17.5;CM-MAC=78:d2:94:ff:07:40;CMTS-MAC=d4:2c:44:7d:1a:ae;CM-QOS=1.1;CM-VER=3.1;
Error (4)
Missing BP Configuration Setting TLV Type: 17.6;CM-MAC=78:d2:94:ff:07:40;CMTS-MAC=d4:2c:44:7d:1a:ae;CM-QOS=1.1;CM-VER=3.1;
Error (4)
Missing BP Configuration Setting TLV Type: 17.7;CM-MAC=78:d2:94:ff:07:40;CMTS-MAC=d4:2c:44:7d:1a:ae;CM-QOS=1.1;CM-VER=3.1;
Error (4)
Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=78:d2:94:ff:07:40;CMTS-MAC=d4:2c:44:7d:1a:ae;CM-QOS=1.1;CM-VER=3.1;
Error (4)
Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=78:d2:94:ff:07:40;CMTS-MAC=d4:2c:44:7d:1a:ae;CM-QOS=1.1;CM-VER=3.1;
Notice (6)
TLV-11 - unrecognized OID;CM-MAC=78:d2:94:ff:07:40;CMTS-MAC=d4:2c:44:7d:1a:ae;CM-QOS=1.1;CM-VER=3.1;
2021-04-23, 09:29:58.0
Critical (3)
Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=78:d2:94:ff:07:40;CMTS-MAC=d4:2c:44:7d:1a:ae;CM-QOS=1.1;CM-VER=3.1;
2021-04-23, 09:30:02.0
Error (4)
Improper Configuration File CVC Format
2021-04-23, 09:30:41.0
Critical (3)
1 Reply
