blueeagle
Jul 07, 2025Aspirant
c7800 no bridge option under Advanced/ Administration.
I need to enable bridge mode on my c7800 because I am installing a ERRO whole home wifi. However, when I go to the router login, under advanced-administrative there is no bridge mode option. Where c...
- Jul 08, 2025
Ok, look for NAT mode. I forgot this model gateway named the mode differently. NAT mode should set to No.
blueeagle wrote:
Unfortunately their is not Router mode under Advanced or any other menu item. I am on latest Firmware VersionV6.01.07
Jul 07, 2025Guru - Experienced User
https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only
Look for Router mode menu feature under Advanced Tab/Advanced Settings?
