crduggins
Sep 07, 2016Aspirant
Cable Modem ethernet ports not working
C7000-100NAS cable modem with Xfinity. The wired ethernet ports are not working. Xfinity/Comcast seems to control the firmware.
DarrenM
Sep 08, 2016Sr. NETGEAR Moderator
Hello crduggins
Did you change any settings in the router recently like modem only mode?
DarrenM
- crdugginsSep 09, 2016Aspirant
Hi Darren,
No, I haven't changed anything recently. Though I didn't test out the ethernet ports when I first connected the modem a few months ago, so this could have been the case from the beginning. I see a "Router Mode" option, but that is set to "Yes".
- DarrenMSep 12, 2016Sr. NETGEAR Moderator
I could suggest to try and do a factory reset see if they work then if not you may want to contact support if the modem is still under warranty.
http://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
- crdugginsSep 13, 2016Aspirant
Not under warranty, but I'll try a factory reset when I get a chance. Thanks.
