crduggins
Sep 07, 2016Aspirant
Cable Modem ethernet ports not working
C7000-100NAS cable modem with Xfinity. The wired ethernet ports are not working. Xfinity/Comcast seems to control the firmware.
DarrenM
Sep 08, 2016Sr. NETGEAR Moderator
Hello crduggins
Did you change any settings in the router recently like modem only mode?
DarrenM
crduggins
Sep 09, 2016Aspirant
Hi Darren,
No, I haven't changed anything recently. Though I didn't test out the ethernet ports when I first connected the modem a few months ago, so this could have been the case from the beginning. I see a "Router Mode" option, but that is set to "Yes".
- DarrenMSep 12, 2016Sr. NETGEAR Moderator
I could suggest to try and do a factory reset see if they work then if not you may want to contact support if the modem is still under warranty.
http://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
- crdugginsSep 13, 2016Aspirant
Not under warranty, but I'll try a factory reset when I get a chance. Thanks.
