amoulay's avatar
amoulay
Follower
Oct 22, 2015
Cable Modem Nighthawk AC1900 C7000 bridge to router
Hi everyone,
I just bought Netgear modem/router Nighthawk AC1900 C7000 100Nas. I was using it as a router, but it conflicted with my other router (NAT), a Linksys. I changed the mode from Router to Bridge, but now I cannot get inside Nighthawk anymore (192.168.0.1). Is there anyway I can get inside? How about reverting the mode from bridge to router? I found a solution on how to keep Netgear as a router with no NAT conflicting issues with linksys router and I would like to try that, but can't, unless I change mode from bridge to Router again. I hope the solution bridge to router is not RESET as I will lose ISP activation (TWC) and have to do it again.
Thanks a lot for helping.
1 Reply
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    amoulay
    thanks for posting on community :)
    If you changed C7000 from Router Mode (NAT) to Bridge mode. You can access the router via Private Subnet (192.168.100.1) by "DIRECTLY" connecting your laptop to the C7000
    If you have problems with that, let me know.
